Well, thought I'd ask some questions here and see if I can get some help.
There is a lot of wind noise around the top side window area. Can this be caused from a window slightly out of adjustment? I had the truck painted last year and had the shop install new window channel. The right side window has a slight bind going up and thought this might be causing some of the problem. I had(have) a problem with fit around the door seals but "adjusted" the top of the door inward a little to tighten this area up.
I also have a loose hinge on the drivers door, I'm assuming this will also contribute to the problem around the doors.
I know these are real trucks and make noise, but it sure would be nice to knock the wind noise down a little. Any suggestions?
