Of course that happened 300 mi from home in heavy snow. Ran my drivers side window down to clear it and it wouldn't go back up. All other windows worked. Tried unplugging the switch and just jumping from the hot wire to all the other leads... nothing. Why not? Ended up unplugging the window motor, using wire leads I switched the two leads around, pressed the "down" button and ran the window up to get home. Question: are there relays in those circuits? Is the switch bad? I know the motor is good.
