Window issue
HVAC Removal with Pictures
'03 tow hooks
I'm having window issues and thought it was the master switch so I just replaced it with a brand new one and no difference. The master will control the drivers, passenger and passenger rear. The others won't work from their doors. I checked wires in drivers rear door as nothing worked in it. Every wire but one was broke so I fixed them all which fixed the speaker and door lock. But so no window. I checked the wires in the other doors and none broke. I'm not sure what to check next.
It sounds like the "Lock" button is activated. That was the first switch in my switch assembly that went bad. If I hit it a number of times it would work again but I'm guessing this prt is also new?.
Yep, I put a whole new master switch in it assuming the window lock was bad in the old one.
I had the same problem first it was the speakers Later it was the drivers rear window it is the wiring it was to tight from the factory even if it dont look like it it is the wires where they go through the door i extended mine because they broke the 2 nd time now i have no more problems..
I had this same problem - windows would work from driver's controller, but not from each door. I replaced the switch and that did not solve the problem. I found that the hot wire from the "Lock" button was corroded off under the threshold of the driver's door. Take off the plastic threshold and there is a channel there that can trap water from melting snow from the floor mat. Soldered in a new piece of wire and everything worked fine.
Blake
