Winter Cover, Now Fan Runs?
D
Got the DW last night
underhood light
I drive my truck 90% of the time empty. Being below 30deg. I installed a winter cover so that it would heat up quicker and run closer to operating temp. Since I installed the Mopar frt cover (half closed) I hear the clutch fan more often than before pulling out from stops, But the temp guage is still at or below the normal range (just below the 200deg. mark) I dont no if the fan noise is just more noticable now with the cover or why is the fan running.
I think you would hear the fan a little more.
I don't think I'd worry to much about it if the temp is ok.
Mine does the same thing some times when it is closed off.
You likely have the heat/AC controls set on a function that requires the AC compressor to run (defrost, partial defrost, etc. ). If so, the fan is probably running because no air is passing through the AC condenser coil.
Rusty
