One potentially serious effect of below-freezing temperatures is the tendency for moisture to seep in between seams - both in vehicles and RV's - and then freeze. This results in the formation of ice, which then expands and slightly opens the seam for even more moisture intrusion, more ice, etc. , etc.
This is serious in areas where roads and streets are salted in freezing weather, but can also affect the seams in RV's as well, and ultimately cause leaks in roofs and walls over a period of time.
Having recently moved from a relatively warm California climate, where freezing weather wasn't all that common, and our 5th wheel was kept under a cover, to our new eastern Oregon home where there IS frequent freezing and no protective cover, I had to improvise.
NO, it's nothing radical or uncommon - but it IS a pretty cheap and easy method to KEEP my roof and walls in good shape, rather than deal with leaks at what might be a very inconvenient place/time...
"a stitch in time... "
Just a friendly reminder, now that winter has arrived!
Happy New Year, and Happy RVing!
