Hello, I have finally had my first problem with my truck that I can't fix. I was useing my wipers and when I shut the truck off then started it up again the wipers wouldn't work. I checked the fuse and it was blown. Put a new one in and it blew as soon as I stuck it in. Tried several more with the same results. Where should I begin?? I refuse to go to the dealer. Also when I removed my fuse cover, the bracket that the fuse block is mounted to has surface rust on it. I don't have any water leaks and all other equipment in my truck works perfect. HELP!!!!!
99 Dodge 4x4 Quad Diesel NV241HD auto. K&N, 4" JRE, 5" chrome tip, matched 275 Bosch injectors, 2. 5" Skyjacker leveling kit, Silencer ring MIA. (more to come)
