Hi all,
I am the one having the issues with the wipers. To recap: 2015 Ram 2500 Cummins, does not have rain sensing wipers. First started with the wipers turning on by themselves for 10-20 seconds at a time, 2-3 times a week. This also happened while the truck was off and key out. Then the ABS light started to come on once in a while, and go away after a while as well. Now the check engine light has come on as well, but who knows, maybe next time I start it, it will be gone too. I checked the fuses (only way to stop the wipers from going), and the ABS and wiper fuses have power across the terminals when the truck is off. not sure if this is normal or not, but every other fuse i checked did not have power across the terminals when the truck was off.
Things I have thought of:
1) Short in the wires somewhere, potentially gotten worse, hence the once in a while wiper issue is now permanent. Also, maybe this is happening with a wire from the ABS...? causing that issue? but why would the ABS light be off more often than its on?
2) BCM is something I've been hearing about. However its not in any manuals i can find, or online, so i have no idea where it is either... could this be it?
3) Multi function switch (signal light/wiper stick) could be done as well. Reason i dont think its this, is that power shouldn't be running to the multi function switch when the truck is off, right? So its not as though the multi function switch is closed all the time... although that would be an easy fix.
I am going to pull all the tires off, check all the wheel speed sensors and wires for resistance, and see if i can find an ABS module (apparently mounted to the rear axle?) and check that as well. Just to do my due diligence, and maybe thats why the ABS has been coming on. It has been a crazy winter up here with lots of temp changes and tons of snow. Although i have been parking it in a heated shop over night and letting everything melt too...
Any help or ideas are appreciated!
