That may not be what that is, But Just below the brake booster is an aluminum block-what would be the proportioning valve on anything else.
It has a wire with a yellow connector that plugs onto a switch in the valve.
It's damaged to the point that it will not reconnect and can't be repaired.
What is the wire and what does it do. I have no lights or codes because of it. It hasn't bothered anything in the year that i've had the truck, but it was there when I changed the fuel filter last week and I want to know what it is.
Thanks for any help.
