Slide still not sliding do to controller not wired correctly , was sent a new replacement without any instructions and tape I used on wires ate up the ink on the ID tags can not read . Has any one a American star fiver with a intel controller and could look at the wires and let me know what you have ,the new controller is a mod 300 and it replaces a smaller controller with less posts I have two green /yellow tracer for motor 1 and 2 a white ground ,a purple for the switch , red with yellow tracer , guess 12v power and looks like Orange with yellow tracer . to 12v control ,but not sure as with this set up fuse blows soon as fuse is put in . Have replaced gears on mechanical side ,Motor will run and move slide if hooked to battery direct . No one seems to know how to hook up the box . Fuse did not blow if box is disconnected I will try to test wires one at a time for voltage etc. Any one with a controller hooked up that could let me know how their set up is could be the way to find out how to rig this one . Thanks for any help have spent over two hundred and fifty and still no go. Ron Bissett in Metro Louisville KY
