Wiring a trailer battery for a winch.
Montana 5th wheel
Short vs. Long bed
Purchased a 14k deckover trailer to haul whatever needs hauled.
Welded tabs to mount a third ramp in the middle so i can load rhinos, atv's ... etc. FWIW i mounted one of the ramps off my 12' trailer and it fit perfectly between the two larger ramps. :-laf
Anyways ...
I welded up a winch mount and want to mount a marine battery on the trailer.
I ran a 10g wire from the 7 pin connector.
My question is;
How do i prevent overcharging the battery?
The breakaway kit had a small 12 volt battery with a "charger".
The charger has three wires;
Blue to breakaway switch
Red to trailer battery
Black to vehicle +
this is apparently a voltage regulator to the trailer battery
can i just switch the small battery out for a marine battery and use it for the winch?
thanks
When I got my Four Wheel Camper(slide in truck camper) they wired in a heavy gauge cable from the truck battery to the truck bed. Near the battery is a battery separator. When loaded, the camper is connected with, what appears to be, a 12V trolling motor plug. Any decent RV service center should be able to advise you and provide the correct parts.
