Well, I'm certainly no electrical engineer. But think of an ammeter like a flow meter in a water pipe - it will only measure the flow going through the pipe it's mounted in.
Regarding charging current, remember that a 136 amp is probably never going to be charging your batteries with that much current. It would probably overheat and explode the batteries. Batteries have a finite maximum charging rate (based on temperature, I believe), so the alternator is regulated to only produce as much current as the batteries can handle at any given time. My gut tells me that ~30-50 amp charging current is probably all you're going to see at any time, except in cases of extended high-current draw on the batteries (such as operating a winch or lots of off-road lights). Don't quote me on that 30-50 amp number - it's just a guess.
The grid heaters draw upwards of 100 amp (I think) each, so you wouldn't want to be monitoring that circuit unless you've got a super heavy duty ammeter.
Tinman, without really seeing exactly how the '01 electrical system works and how you've got it wired I'm not sure why you were able to read different things there.
Ryan
