wiring diagrams
Fan Pulley Froze up
There's about 20 pages of wiring diagrams in my '93 service manual - what exactly are you looking for? I can make copies a fax them to you if you can narrow it down a little.
Happy trails
Bob
Thank you Bob and Gary...
I am looking for the wiring diagrams for the engine harness(es) that go from the engine to the large square plug to the dash and the computer...
I am still in the process of putting this conversion together...
I would like to install a tach and hook up all the necessary electrical components... alternator/charging system, instrument gauges, etc.
-If you could fax them to (916) 786-3999 attn:Christine
that would be great.
Thank you for your help...
... Robert...
Can I jump in and get a wiring diagram???
Bob & Gary;
I've been trying to figure out what's going on with my Cruise Control and Speedo. Would it be possible for me to get a '92 wiring diagram copy from one of you? (The speedo is very jumpy and innacurate and the CC doesn't work at all). If you can email it that's best but you can do it on my nickel if by fax.
Thanks in advance;
Smiley
Smiley,
The problem with your speedo/cruise control is probably the speed sensor on the transmission. I have replaced mine twice now. When it is bad the speedo bounces all over and the cruise wont set. Hope this helps.
Rod
Smiley
There is another possibility if you've got the Getrag 5spd. It requires tightening the nut on the back of the transmission output shaft. Just post on PM me if you do and I'll run you through it.
Bob
Bob & Demon:
It's an auto transmission and I've heard of the sensor problem on this site - so, I've just replaced the sensors twice within a week! The original one would go OK for a while then crap out completely (like on a long trip when I wanted real bad to know my mileage) so I got a replacement from Napa - Echlin part # VSS100. The first was way off on the speedo by about -15 mph. affecting the shift points - the next was more accurate but has started to bounce and seems now to be off by about - 5mph. This has made me think that the problem is somewhere else or that the part is wrong or maybe I need to try yet another??????? This is why I'm looking for a wiring diagram to trace the wires to the speedo and see if there is a short or bad ground or whatever. The problem sometimes (not consistently) is worse in the rain. Any ideas? Oo.
Demon Et. al. :
