Wiring help needed
TST power kit
Excess Black Smoke Still Has Me Stumped
Truck is a 98. 5
My electrical Engineer Buddy needs some assistance from somebody with a wire diagram
question is the MAP sensor connector
Looking into the end of the connector that plugs into the MAP sensor, with the wires going away from you, And the latch up, it looks like a triangle with 2 wires on top, and one on the bottom.
I think this is the wire colors
LT=Black/Blue strip RT=Orange
Bottom=Green/Red strip
What are the different wires.
I had this in my notes at one time, but lost it.
I think they were
Orange = Voltage to sensor (5V or VCC)
Black/blue = Ground
Green/Red = sensor output to ECM.
Thanks
TowPro
Tow Pro,
You are correct.
Pin A=Orange - 5V supply to sensor from pin 10 on the PCM
Pin B=Black/LT Blue stripe - Sensor ground from pin 11 on the PCM
Pin C=Green (or Gray, depending on year)/Red stripe - sensor output to pin 8 on PCM
FWIW: Pin A and B (edited!) also feed 5V and ground to the oil pressure sensor.
Dave
Thanks Dave: BUT this raises another question:
If Pin A is 5V, and from what you write, it sounds like pin C is the sensor output (varying voltage FROM the MAP sensor)
How could pin C also be used on the Oil Pressure?
Just making sure I understand you.
I thought Sensor output would be the signal or voltage that changes with boost pressure that COMES from the sensor?
Did you mean that A and B are also used to supply 5v and ground to the oil pressure circuit?
Sorry
TowPro
Originally posted by Dave Fritz
Tow Pro,
You are correct.
FWIW: Pin A and C also feed 5V and ground to the oil pressure sensor.
Dave
