I have a conversion in the works... . Need a little help from you experts out there. . The problem is the starter relay that was mounted on firewall next to battery on my 89' model. . I have figured out how and where all wires go except for the small brown wire with a yellow stripe. . I really did not pay super close attention before removal from the 89'; I only used a test light and it showed no juice when i checked them all before removal... Now that I have her sitting in the new truck I cant get her to start without it connected. . Called a buddy and he said disconnecting the wire had the same effect on his 90' , but he is worse on wiring than I, so any help will be greatly appreciated fella's. .
