Blew the fuse for the ignition system on my truck. I am able to start truck now by running a fused jumper wire straight to the relay from the battery. If I use the ignition switch it blows the fuse again. ($5 fuses!)
But since have found all kinds of problems. None of the heat controls work, no back up lights, power windows don't work and more.
Tested the wiring for the ignition system from the fuse to the relay and it does not show any grounding.
Replaced the ignition switch and there was no improvement. Suspect it's a wiring issue but the only way to test the wire harness is by removing or replacing it.
Any help would be appreciated.
