Can someone explain how to wire a pair of KCs on a 02 3500 using a three pos. toggle switch, one position is on at anytime, the other is on with High beam only. I had them wired through relays on each circuit & switching the power. That way the KCs stayed on if in the High beam position & the headlights are turned off. Someone told me that the truck is wired so the Gr. is switched. But when I tried to wire that way the KCs go out when the headlights are turned on, & the highbeams won't stay on if the switch is in that position. :{
