wiring question
Help Me Get Set Up!
Boat in a toy hauler?
does anyone know what color does what on an 04 dodge with factory wire harness I know that dodge changed the wiring on 7 way plugs
Here's a copy of the pinouts on the connector hope it helps.
<img src=https://www.turbodieselregister.com/user_gallery/sizeimage.php?&photoid=10695&width=2/src img>
In the circuit column is wire guage and color, the slash means stripe color - WT/LG White with Light Green Stripe.
I think the above table is for the rectuangular connector that plugs into the vehicle side of the 7 pin RV connector. Here is what I came up with on the 7 pin plug, looking from the trailer side of the connector. The 1st set of numbers is the pin on the connecter from the table on the previous post. Make sure you verify what I have here as my notes are not very complete.
(4) 1 o'clock - Red - 12V Battery Charge
(2) 3 0'clock - Lightt Green - Right turn and stop
(7) 5 o'clock - Dark Green - Brake
(8,9) 7 o'clock - Black (2 ea) - Ground
(10) 9 o'clock - Yellow - Left turn and stop
(5) 11 o'clock - Brown - Running Lights
(3) Center - White/Green - Back Up Lights
You can find the complete wiring manual on-line at http://www.dodge.com/bodybuilder/
