boost will the stock Holset handle? With "Max" boost and EGT set points of 40 psi and 1400 degrees, some overshoot occurs prior to backdown fueling. My digital guage captured these readings:
https://www.turbodieselregister.com/forums/attachment.php?attachmentid=50242&stc=1
I will replace the stock unit when it becomes more clear which will be best for my use. Until then, what should boost be limited to? Stated differently, what is probably safe, and what is dangerously high?
I am happy with the Edge product so far. Some pictures if install in gallery.
