Nate said:
I don't understand how a fire extinguisher wouldn't work?
If your killing the oxygen... which is how a fire extinguiser works... . ain't gonna be a flame in the cylinders.
Nate, here plain and simple reason it works. To stop any type of combustion rather it is open flame or the combustion in the engine you need to understand it what it takes to have combustion.
It takes 3 things to aquire combustion, Heat, Fuel and Oxygen. If you remove anyone of them, the combustion will not continue. On a diesel engine the fuel is diesel, the oxygen comes from the air intake and the heat is produced by the high compression in the cylinder.
When a diesel starts pulling engine oil past the turbo, shutting off the diesel fuel does no good. In fact, a diesel will run faster off engine oil that diesel fuel. The oil will fill the cooler so now shutting off its fuel source is nearly impossible.
Since the heat is generated by compression, unless you can find a way to stop the engine from turning, the compression will be there.
This brings us back to oxygen again. In my opinion, the best and easiest way to remove the oxygen is by using a CO2 extingisher in the air intake or air box. Halon or any inert gas will work as long as you can get enough to lower the oxygen below 14%.
Some say use a plywood board. If this is done, make sure it is a substanual piece of wood. I have a friend that had a military diesel run away on him while test it on a test stand. His first thought was kill the fuel but had no result. Then he took a clip board in his hand and put it against the open turbo intake and it accually broke the clip board and sucked it in. It finally ran out of oil and blow up sending pieces of rods and block all around.
Hope I never see one and if I do, I think I will stand to the front at a safe distance and watch the show.
