It is also very important to know what your fuel pressure is at all times,some have a fuel pressure guage in the cab,some just check fuel pressure at the vp44 pump once in a while,but if fuel pressure gets low enough it will take out the injection pump... Big Bucks. . Also if you haven't changed the fuel filter in the last 12,000 miles i would put one in soon,because a pluged filter will let very little fuel to the injection pump... running good one day,filler up with bad fuel,,and no go... I hope you find the problem.
