I replaced my slave cylinder with 360051, and the truck will not go into gear. It has steadily been getting worse (going into gear), so last weekend I pulled the slave out (did not disconnect the line) and reinstalled. The truck shifted a little better. So I replaced the slave. I know the piston is moving, I left it out of the transmission and pressed the clutch to the floor, the piston moved all the way and I could not push it back until letting up all the way on the clutch. So I know it has good pressure and assume there is no air in the line because of piston movement. I tried the old slave same result. I tried the stock piston in the new slave no different. I have had a Cerramettalic clutch for a year with no problems. There are no leaks anywhere. Like most of us I have to have this truck running! Any help is very much appreciated!
Damon
Damon
