Wait a minute, you are all over the place here with symptoms. Either it was idling at 800 rpms and jumping to 1500 rpms or it wasn't, you cannot assume rpms from feel.
Now knowing it is an auto, and you said it seemed to slam into gear, did it also try to push thru the brakes when stopped? If you see a jump in rpms and wanting to push thru the brakes it should not do that in park or neutral. Symptoms like this point directly at the TQ converter in the transmission. Remember, we cannot see or feel what you do, you have to be specific on rpms, symptoms, etc, or you will not get correct advice.
