bryondodgen
Howdy, I am so close to passing smog and can't figure out this code P2509. I checked the grid heater relays, they have 12.53v going in and about 10.20v coming out, when key is turned on before cold start. I am not sure if this is correct because it is using power when on. Should it be closer to the 12.5v I have at hot side of relay? I have new terminal post connectors and will load test these 1.5yr old batteries to make sure its not them. Or am I on the wrong track for this code altogether? Any info on this P code would be much appreciated, and what all this has to do with passing smog is got me super frustrated.
