Archived Wont Start After Fule Filter Chng
Archived HELP!! Lost AUTO trans over RR tracks ??
Archived Truck cranks for 10-15 seconds before starting
Wont Start After FuelFilter Change
99 SLT Stock/ old style fuel filter. (remove from bottom). Replaced filter bumped starter to fill filter. No start. bled fuel at vp banjo. lots of pressure caused a mess. No Start. Cracked injectors 1 3 4 and bumped eng 6 to 9 times no air no fuel at injectors. Lift pump IS supplying plenty of fuel. Tried starting it with accelerator at 1/2 no joy. HELP
I have read and tried all the "wont start posts" but no lhelp. How many times do you need to Bump it before the fuel gets to the injectors
I'm not sure about the bottom loaders... Did it come with a rubber O-ring like the newer ones?? Since the lift pump is working, make sure you have a good seal at the filter housing. You may not see or hear one. That's the only thing I can think of, since everything else is ok... . must be sucking air and not pushing fuel to the injectors..... Hope this makes sense and helps.
Oh, and welcome to the site:)
Thanks Truckstom, All is well that ends well.
I must have bumped that poor LP at least 15 to 20 times. and never a sign of fuel at the injectors. Finaly out of desperation I re-tightend the injectors and just cranked it over about 15 sec. Wow the most beautiful music. It is running like a top. I had bought it used from a pp and I changed every thing today and boy did it need it. Thanks again... Charlie from NO Cal
