So in reading the many posts on the board, I guess I've been really lucky with my Dodge and the common Rail Injectors.
I picked the truck up (2003 in profile)at 76k miles, and had to have 2 injectors replaced in 2005...
I now have 297K miles on it and have done nothing but normal maintenance, clutch job and an FCA and pigtail at190K
I did the muffler eliminator kit and use a Smarty JR on Torque
I change the Fuel Filter at 5k and the oil a 10k (Amsoil)
I don't have a FASS or 2 micron filter kit. . ( But after reading, I’m getting one)
So I run 120 miles a day, steady speed at 55. With the Nitto 37's I usually run 1400 rpms. .
so I usually get 23-24 mpg (pin and paper)
I run injector cleaner religiously in it , every tank full, every time and I always do a full fill at 1/4 tank. .
I run the 4150 Amsoil micro fiber air filter, gets a vacuum and blow out at every 5 k
Back in June, I started noticing a decline in the MPG... and in retrospect, it was taking longer to start.
So last week, on my commute in, I stopped for fuel and when I tried to restart it would spin over like always, but wouldn't kick off... so shot a little either in the filter and it started. Seamed to run fine, no codes... that afternoon after work it started after cranking for a long time (5-10 seconds), next morning same deal long crank time, but did kick off…. so Wednesday I had to drive it, as the wifey had to have the other car, and when I went to crank it, it spun over but wouldn't kick off without the ether... same when I went to leave work...
Once its going it still runs strong, doesn't balk, sputter or miss, no smoke unless you stomp it, lots of power and no codes. .
So I uninstalled the Smarty JR, just in case, no change. Checked for codes, none, and cleared it out anyway… changed out the Fuel Filter, no change. Had a spare FCA, so swapped it out just because. No change. No fuel leaks. Starter spins it over like it always has, not dragging or running slow. .
So now my fuel economy is down to around 19 @55, this, the hard staring and the 297K miles leads me to believe that it's time for new injectors...
Or am I missing something...
