TCluff said:truck takes forever to start, sometimes it wont start at all, no codes, no smoke, 25 psi inlet fuel pressure, is it the tst![]()
JStieger said:They were some sort of actuator on the CP3 itself.
rbattelle said:That's the Fuel Control Actuator (FCA). It's purpose in life is to distribute and regulate flow to the CP-3 and back to the return line.
It *might* be possible to damage the FCA by running excessive fuel pressure. 25 psi is a lot of pressure. Now, I know lmills has been running up around 25 psi for awhile and he's had no problems.
Cummins doesn't publish any specification that indicates the maximum inlet pressure to the CP-3.
-Ryan
JStieger said:The guy I talked to made it sound like a relatively easy fix instead of throwing money right away at a pressure relief valve (which TCluff did to no avail) or the hassle of getting a new CP3 (which was the other option offered to solve his low rail pressure problem, but not a particulary appealing option if having to deal with the local dealer). I hope he gets his truck fixed because when it is running right, it runs like a raped ape! Anyhow, I should have got a part number and cost! Maybe I'll email the guy tonight.
On another note, if injector solenoids are sticking open or closed, can the solenoids themselves be replaced or does the whole injector have to be replaced as a unit assembly?
TCluff said:thanks for the information, i will try the fca i was just reading about that in my service manual, i am kind of wondering about the cascade overflow valve also, do you know if they can go bad and bypass too much fuel ?![]()
