Engine/Transmission (1998.5 - 2002) Won't Start
Engine/Transmission (1998.5 - 2002) B1 turbo results to date
Engine/Transmission (1998.5 - 2002) installinf fuel sending unit
This is a puzzle. The other morning i went to start my truck. It fired weakly for 3-5 times and quit. I tried restarting several times and all it would do was turn over, at the usual speed, but not fire.
Fuses all OK, fuel pressure 14 PSI after the filter. No wires seemed loose-that I could see. I removed the EZ EDge chip and tried again. Still cranked but didn't fire.
i had it towed to the local Dodge dealer as it is still under the 100k warranty.
They had it 2 days and could find nothing wrong. It started every time they tried, no fault codes were found. (I didn't find any either).
Has anyone had a similar problem? If so, what was it and what did you do?
I don't want it shutting down on me in the middle of nowhere, with or without my trailer.
