Won't start
overflow valve
Speed Control Servo Cable
Just installed EGT and boost gauges. Started truck and everything seemed fine. Two days later truck will crank but not start. Did some searching on TDR and have some things to check.
One problem, where is the fuel shut-off solenoid??
Thanks for any help,
George
crank but no start?
one is pump running when stating switch position ? Air in system ,bleed air at filter and banjo bolts? check fuse inside truck and under hood , relays switch around ? Batterys and ground . last resort call the hook I did on mine and it was a fuse link or fuse no charge at five star. Hope you find it any members of TDR near you that can offer help? Ron in Louisville KY:confused: :)
Starts now??
Towed to dealer. When he went to look at it this AM, it started no problem, no codes in computer. Will have to wait till next time to find problem (hope not).
