Wood screw in a tire
2001 Arrival Time
auto transmission problem
I picked up a wood screw in the tread area on the inside rear tire. I have been told to just leave it alone if the tire is not leaking air.
Since I carry a heavy camper, should I have the screw removed and the tire patched?
Thanks for your help!
2001, 3500, 2X4, QC, SLT, Auto, 3. 54 gears, camper and tow packages. Lance model 1130 camper. Rancho 9000 5 Speed shocks. BD Brake, autoloc, pressureloc. Hadley air horns. OEM bugshield w/eyebrows and dash cover. Member San Jose Ram Runners.
I have driven a dually for a lot of miles just to find a bolt in one of the inside rears. I know it had been in there a while because of the wear it had on its head. I would still recomend pulling it and patching the hole. You never know when something will jar it loose and you will start getting a leak. Just my . 02.
2000 Dodge Cummins Diesel
6 sp manual, every option except automatic and sports package!! SnugTop Shell and Professional FireFighter License Plates. (To match my Flame Red Truck of course!!)
Pull it and patch it. It's always the inside rear tire, isn't it? The front tire kicks it up and the rear tire grabs it!
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, thermostatically controlled twin 14" Permacool electric fans, intercooler), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, Click on: <A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus" TARGET=_blank>http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus</A> saves!
I've been carrying a Safety Seal kit like this for almost two years. It cost 54. 00 and has saved my butt several times. I was at TXRams place last Saturday and saw a nail in my left rear tire as I was about to leave. He asked if I was going to plug it now and I said yes, it will take me longer to find the nail again when I get home than to plug it now.
I've used three plugs to patch a hole caused by a large lag bolt several years ago. I've also plugged at least a dozen holes in the tires on my wife's car.
http://www.safetyseal.com/
243
99 QC 2500 ST 4X4 SB 24V/5speed 3. 54/LSD Driftwood/Agate
Walker 21468, VDO, Bridgestone 285/75/16 MT's, RS9000's, Hella 500's
-- email address removed --
243,I have a kit similar to that I use on the orchard for my equipment,can't even begin to figure how much down time it's saved. Probibly paid for itself at least 500 times over in just lost time saved,especally when you have to deal with a tractor tire that's filled with 1200 pounds of calcuim choride.
As for the screw,it will probibly be fine until you're miles from nowhere,fix it ASAP.
243,
Which kit did you get for the Dodge? The auto or truck kit? I'm thinking that the tires on our Dodges are more like car tires and not real truck tires. About how much does the kit cost?
About 70% of the time I get a screw/nail in the tread area it doesn't even leak when you take it out.
BTw - I carried a repair kit and can of fix-a-flat with me on the ATV so I wouldn't have to walk back to camp.
243 - What are the particulars on this kit-Mfgr, Kit model #, Price, where you bought it, other models available?
Thanks for the tip - I drive in the Sierras - North of Lake Tahoe and feel better with all of the insurance I can get.
Jim E. - Newbie to Diesels w/2001-2500Quad-4X4-LB-Bronze Beauty
Red, I go along with the others... fix it or end up putting the spare on when you really don't want to. If it were me I'd go to Les Swab, have the tire fixed (probably for free), have them rotate all the tires per the owners manual and be on my merry way.
Dave
243, You da man! Guys, the Safety Seal Kit is to tire plugging kits what the Cummins engine is to pick-up truck diesel engines.
Get the picture?
I've lost count of how many back-roads repairs I've done with this kit. A year or two later, "strangers" will approach me and say "hey, that tire you patched is still going strong!" Probably the most grateful was one fellow who had apparently gone through a nail field - three flats. He had a spare, but that still left him two tires short. My friends now call me over when they spring the leak, just so they don't have to get down the spare...
Guy's, I see nothing on the box that id's my kit. When I called the distributor for my area, I said a tire repair kit.
It may take a call to Safety Seal to determine the difference. I had to call to locate a distributor in my area.
The Texas distributor is:
John Landers of Tread Care
Pager 713. 762. 0789
Phone 281. 352. 3061
Good Luck, 243
HEY I think that's my wood screw! #ad
Just kidding. #ad
Take it out get it patched. It mite come out just like in your nightmares #ad
65 mph going around curve. #ad
[This message has been edited by Missouri Mule (edited 12-31-2000). ]
