2nd Gen Non-Engine/Transmission Worn Wireharness
Engine/Transmission (1998.5 - 2002) Hard starting sometimes...
Engine/Transmission (1998.5 - 2002) NV 5600 Info Please.......
I tabbed my KDP today and found another problem. When i removed my upper rad hose i found that the wire harness under the hose had been worn through. The factory plastic cover is installed with the split side up, this allows the hose to seperate it and rub on the wires inside. Two of the wires were rubbed through enough to show copper. I taped the wires, taped the harness, taped the plastic cover, installed a piece of split rubber hose over everything with wire ties. The harness was also wearing on the rad hose i will be changing that this week. Just an FYI for everyone to check next time your under the hood.
