At WOT, the PCM will shift and lock based on RPM and engine load, not really speed. The speed will be determined by what boxes you have turned on at the time. WOT shift points/lock-up is treated differently than when your just putting around, which is based somewhat on speed. It is not going to lock in all gears whether your at WOT or not unless you have some sort of transmission controller to command it and an aftermarket valve body that will allow it. I don't believe the stock valve body will allow lock-up in 2nd whether you have a transmission controller or not. For me at WOT, letting the trans do its own thing (not using lock-up switch), mine won't lock until I hit redline in 3rd and the trans goes into high gear. Hope I didn’t make that sound confusing.
