I have been making my own and running B-100 in my truck for a year now. My truck has been running just fine on it. I did alot or research before I started. The best book I read was called " From the fryer to the fuel tank ". The book said as long as you do the glycern seperating process proplerly, you do not need to wash it. I change the filter around 6k and it looks almost new. I had 2 inccidents, one was in the beginning using so bad oil. Truck was hard to start up ran rough for a few mintues blew alot of white smoke and then burned through the rest no problem. The other was just a few weeks ago when I did not perform any kind of winterizing, temp hit 32F overnight and the fuel filter clogged. New fuel filter some #2 in the tank and was on my way.
The truck had a good check up about 6 weeks ago. Engine is fine the injectors are fine.
Fuel flow is normal. No engine problems to speak of.
I decided to purchase a system online. It was less expnsive than most of the ones you see. The less exspensive one had some trade offs. I had to assemble it, less automation and pvc piping was used. Roughly about $600 of actual material.
Your first batch is always the most difficult, mainly the titration test. I would not have minded someone holding my hand for my first batch but I got through it just fine. Other than knowing how much methanol and lye to use and figuring out how you want to heat the oil up, you can make it as simple as putting everything in a 55 gal drum and using a drill and heavy duty paint mixer to mix it, I've done it. Yes thier is a little more detail but you get my point.
I have alot of good info for getting your titration supplies together at little cost. You can make some small batches in your kitchen. Hope this helps.
Wyatt
Atlanta, GA
