lmills said:the 40's were originally designed around the stock cp3. I would givem a try.
lmills said:640 HP has been done on a stock CP3'd truck with the 40's and a TST /BDDL stack and a VA pressure box
Remember! The 40's were originally designed to compliment long duration boxes like the TST![]()
CStraface said:What year was that truck?
All I know is all trucks must not be built the same, because my truck is hurtin for fuel with my tst on 2/2 and my bully dog on performance. Starts poppin and temp starts climbing at WOT. Almost seems like it works better when BDDL is on CL. Go figure???? But I sware, the RP gauge reads higher and no popping and lower egt's on CL vs. Performance. Reb thinks it could be the rail sensor. I'm just going to get a Cp3 and hope it fix's my problem. It's like when the doctor tells you that your body can handle 3 pills but you should only take 2. Well I'm takin my chances and goin with 3!![]()
Summit said:Turn your mp8 off while just cruisin, my rail pressure box makes mine real touchy/surgy when on,,, higher setting + higher rpm = worse.
if it still surges with it turned off than it sounds like the fuel actuator is bad on the cp3.
Aslo it might sound stupid,but what does WOT abb stand for,I have been trying to figure it out
lmills said:The truck was an 03 truck that is owned by Richard Martin (AKA Gypsyman and the owner of Glacier Diesel).
CStraface said:Yea, I figured it might be an 03 or early 04. These 05's, with the third shot of fuel, rails seem to drain a lot quicker then the earlier 3rd gens. IMO.
kdbvulcan said:I can turn all of my mods off and put it back to factory,and it still does it,even when you cruise,of course not quite as bad cause you aint dumping the amount of fuel in there,but bad enough where you dont want to use youre cruise,so you still think its my fuel actuator,if so where do you purchase one through,the dodge dealer
