So i have a 96 12 v and all of a sudden i noticed a fuel leak = blew out the gasket at the top of the fuel filter
replaced the fuel filter and then noticed ----> the fuel hose elbow from the preheater to the lift pump was pancaked down (almost as if it was starved and suction was too great
i checked the screen no blockage replaced elbow
truck was extremely hard to bleed ---- i hooked up a fuel pump got it bled and started
rough idle with pump and wont idle at all without the electric fuel pump used to bleed the system had to keep it above 1700 rpm
i have new marine fuel lines, deleted the fuel heater, and replaced the pancaked fuel elbow
personally i think there might be a problem with the lift pump but at this point I have no clue
need yalls help
i think the cure might be a helman fuel sump and a fass 220gpm HD (bypassing the fuel heater lift pump and fuel filter)
what do you guys think
I'm located in naples FL (truck is in front yard)
need yalls help
