I'm not trying to sell anything here guys but just want you to be aware of the potential issues with different ladder bar setups so you can make informed decisions. Ladder bars have to be designed properly in order to allow for proper suspension articulation (for now I'm mainly talking about both tires moving in unison - ie on the street, although this also affects being able to "cross-up" the suspension) otherwise you will get suspension bind.
As your axle moves upward (relative to the frame) it has to also move rearward for two reasons. The leaf springs in the rear are attached solidly at the front and with a hanger at the rear, because as the axle moves upwards the leaf spring pack gets longer (measured from eyelit to eyelit) hence moving the axle rearward, the axle housing also rotates some rearward because of this.
If you have ladder bars that have a fixed mount at the axle (either clamped to the axle or attached at two points on the axle) then you have to have a shackle mount at the front mounting point of the ladder bars to allow this and it has to be properly designed (geometry equations - as with ANY good ladder bar design) - if you have a solid mount at the front and a totally solid mount at the rear (2 mount points or a clamp style mount) then you have virtually eliminated any suspension travel you would otherwise have - read rough ride and hard on parts. The biggest problem with this style of bar (fixed mount at the axle) is that when you put a heavy load in the truck or behind it that will settle the suspension you are either 1. putting a HUGE stress on the mounting points for the 2 point type bars or 2. putting a HUGE load on the clamp on the bars and in order for the rear end of the truck to sag the clamp will have to slip around the axle.
Also, many of the ladder bar setups out there require you to remove your anti-sway bar. Ladder bars DO NOT replace the function of an anti-sway bar, unless they restrict your suspension travel - in a way that's kind of what an anti sway bar does. Ladder bars should only locate the axle fore and aft (with the proper amount of rearward movement of the rear axle to allow for proper suspension travel) and not in any way shape or form stop the left side of the axle from moving upwards versus the right (full suspension travel). An anti-sway bar simply applies resistance from one side of the axle moving without the other doing so (but still allows flex and suspension travel - although less than if it was removed or disconnected, hence the sway bar disconnects that are sold to off roaders).
Also, AFAIK all of the off the shelf retail ladder bar kits out there use bushings for their attachments (I could be wrong on this though) and at least some of them are very wide. A bushing restricts the amount of twist that a ladder bar can produce which can reduce travel in a "crossed up" suspension. For most diesel drivers that is not a consideration - but some of us do off road and that's when this becomes a concern.
Last point is that there are different quality components that you can buy. For example you can buy regular 3/4" heim joints for $10-$15 ea or you can pay $30-$45 ea for moly heim joints - there is a difference, the regular heim joints will rattle soon after installation whereas the moly heim's won't.
I've avoided putting any names here on products because I do not want to be known as someone who talks products down to sell my own. Just wanted you guys to have a complete picture so you understand what you're looking at buying. I'm only posting my signature here to stay within the guidelines of the forums - if you want to blast me for this post go right ahead I understand and will take it like a man.
