Does the tach and speedo work, does the truck start and run? If they do than you will have to start chasing the electrical bugaboo's common to the grid heaters. If the tach, speedo, charging system don't work then unplug the crank sensor, turn key on, if wts comes on replace the crank sensor. Issue 52 has info on the grid heaters.
