fuel and wvo
sure thats a good price but how do you prefilter the oil dieselcraft says it need to be prefiltered to 100 micron or better then you can heat it up and centrifuge it. The oil needs to be heated to 140+ degrees 180 is best and nothing over 210 degrees.
then if you use that hose they supply (braided pvc) with heat if used that hose gets hard really hard, forget trying to uncoil it in the winter and if you pump hot oil over 150 degrees the hose will bubble.
I am not saying this wont work it will its the same stuff I use filter,pump drum and centrifuge building one and have one on order for another project.
Its just not as easy as running the oil thru the filter once and then of the the truck.
I was told buy the owner of Dieselcraft that the oil needs to go thru the centrifuge at least 4 times before its clean using the oc-20.
but yes, all in all its a good deal
cj hall
