So, besides good filtering, is there anything else necessary to run around a 30-50% blend of oil/diesel? I have seen these "biodiesel contraptions" and if it is not necessary, I don't want to waste my money on it. I just ordered a 20 gpm pump to transfer the oil from the 55 gallon plastic drum I set at the restaurant to another drum on my truck. I will then filter it at my shop before use. Currently I have been putting in simply filtered WVO in 5-10 gallon batches in my '96. Do I need to do anything further? I am happy with performance. The engine runs quieter and smokes less. Power is about the same. Does a WVO blend affect a computerized engine such as my Liberty and '03 common rail? Does it perform fine in the first generation engines with lower injection pressures? I know they do not like used engine oil, which I have no problem running in my '96.
Thanks for all the help. Now that I have a second (REALLY GOOD) source for WVO, I want to fully utilize it in the most economical way.
John
