xfer shift lever mount on NV5600?
Ford E4OD trans in Dodge Ram?
2001 dodge donor on ebay
Anybody know how the transfer case shift lever assembly from my '93 W250 should be mounted to my '99 NV2600? The old Getrag had three bosses drilled and tapped for the mounting plate, but the new transmission has only one boss and it is not tapped.
Once I get it mounted, then I'll can deal with lengthing the rod to reach the transfer case.
Thanks,
Gil
I ended up having to fab a mount and bolt it to the PTO cover, I used 3/8 studs with a nut to hold the cover then bolted the mount on top, hope this helps. Bob
