I have several questions regarding installation of a Delphi MyFi XM system in my '03 which has the AM/FM w/6 cd radio.
1. Any suggestions as to where and how to run the antenna wire from the roof to the MyFi car cradle which will be mounted near the factory radio?
2. Where and how should I connect the car cradle to +12v? I would like to hard wire it, especially since the MyFi cradle will probably be located directly in front of the cigar lighter hole.
3. Is it possible to run the MyFi audio output directly to the factory radio? Or must I use the MyFi's built-in FM transmitter to transmit thru the air to the factory radio?
Any ideas will be appreciated.
By the way, I definitely want XM instead of Sirius so that I can listen to baseball games.
Glenn
Glenn
