BD X-Monitor
I, also, have the X-Monitor, pyro & boost, only, & am very happy with it.
I, originally, tried the DiPricol's with a dash mount pod but, at that time, 3rd gen. pods were not available & I had to try & customize a 2nd gen pod. It didn't look like it was going to work too well, for me & no one, at the time, could tell me when the 3rd gen pods would be available.
The DiPricol's were purchased through Geno's Garage & they gladly exchanged them for the X-Monitor.
I use the grab handle, all the time, due to being "vertically challanged" (read: short) & the X-Monitor allows you to retain the handle. The guage fits neatly under the handle & is easy to read.
I, also, read about the problem with sunlight shining on the guage screen so, I built a sun shield, or hood out of a plastic switch box I bought from Radio Shack. Painted it the same color as the X-Monitor pod & painted the inside of the hood flat black. The hood extends out about an inch & works well at shading the screen. In very few instances have I had a problem reading the screen. It does happen though, but, rarely. Not enough to be a problem.
I, also, had a problem with properly mounting the under dash box. Kept falling off & the boost hose would come off. I finally got it properly secured & it has not been a problem, since.
The bottom line is, I'm happy with the product & would recommend it. The memory feature is handy, also, especially when documenting your performance enhancements.
Joe F. (Buffalo)
