y2k 3500 Air Conditioner - Full Time?
Mat-Trax for a Ram?
Geno's Manual Transmission Filter
Hi,
I'm just wondering if the air conditioner compressor in the y2k trucks runs all the time or does it cycle? Other than the "Max-Air" position of the air conditioner, at what point does the compressor cycle?
I'm thinking about installing a switch in the compressor clutch circuit to disable the compressor so I can just get fresh air vented into the truck. Migh just help fuel mileage too. I dunno...
Anyone?
Hey neighbor, I'm just down the road here in Sachse.
To answer your question, on my 00 3500 the a/c will also run in the split mode (floor and dash) and defrost. It does not run in floor only or dash only. I sure like the 96 set up better. You could turn off the fan.
2000 3500QC 4x4, 6-speed, 3. 54, Patriot Blue, SLT+, every option, mopar brushed aluminum side rails
Hey wcharlie,
Welcome from another North Texas neighbor here in Argyle(just south of Denton).
My Y2K 3500 opreates like Chaw's. I don't mind the fan controls since I never turn it off. If you'll listen to your enginr idling in Neutral, with the A/C compressor cycling, the electronics compensates for the additional load on the engine--pretty responsive.
If either of you have the time, there is a local TDR meeting at 8 AM at Bic's Coffee Shop tomorrow. If you need directions, e-mail me. We have get together each month for breakfast, some parking lot show & tell, and good fun(B--S--).
Y2K "Limited Edition" 3500QC, 6 Speed, 4. 10, SLT+, Camper & Tow Pkg. , (New)Factory Towing Mirrors, Westin Chrome Nerf Bars, Mopar Flaps, Reese 20K Hitch, EGT & Boost Gauges, RPM 45 Gallon Aux. Fuel Tank, Highway Products 5th Wheel Toolbox, PacBrake, Painless Wiring Kit, 8,000+ lbs. of Driving Pleasure since 12-16-99!
d/c back to modelchange in 94 a/c 's run all the time any time of the year,
latest tech, blend air theory,
deal's with foging of the inside of the windows...
cut out the a/c and the fogging comes back. .
defroster (cold climate) won't operate correctly.
if you notice there is also no hot water shut off to the heater hose's. . now the jog of the blend air door.
in short leve it alone!!!
96-3500 SLT EXT. CAB AM/FM/CD-RINO LINER. D-CELERATOR EXH. BRK-RED LINE VAC. OVER HYD BRK CONTROL- AIR BAGS W/HVY DUTY AIR COMP. PUTCO S/STEEL DEEPBOARDS FRONT TO REAR. REESE 20K 5TH WHEEL & GOOSE -REESE 20K HITCH BELOW W/17K RECEVER. CLEAR COATED & SOUND DEADINGING &UNDER COATED 5 SPD/W 4:10 MCHLN'S 235/16'S UNIDEN PC76/WEATHER-WILSON 1000 MAG MOUNT ANT. 4 WHL ANTI LOC BRK SYS.
