I'm installing gauges this weekend weather permitting. I've read and researched this site on the details of tapping, boost bolts, trans-cooler hose adapters, grease or no grease, engine running or not, 1/8 or 1/4 pyro, wire taps, A-Pillar/dash and color codes etc.
I have pestered a few people at work too and my fine-feathered-ford-friend told me I could use a shop-vac in blow mode at the tail-pipe to put positive pressure on the exhaust system while drilling and tapping the pyro hole. I never heard of this technique... he also said most people use too much speed and not enough pressure or too much of both when drilling and too many revolutions of tap before backing out chips. Low speed moderate pressure and back and forth revolutions with the tap feeling for the cut and chip sounds like the way to go. Not to worry so much about debris as the velocity they would have and their size would not have any impact on the turbo and the most critical concern would be that I not break off a bit or tap in the manifold.
Another guy said water is the best lube for drilling cast iron and all I need is a little spray bottle of water to wet the bit. hmmmm.
I could not find a NPT tap at Sears or Home depot so I went to Graingers and they must have known I was coming. It cost me almost $60 for two taps ( 1/8 and 1/4") and three bits, (they're reference chart says 1/8th NPT requires a Q bit so I got a Q and an R) For those who plan better than me,
http://www.dieselmanor.com/dm_products/TAP1418.asp
seems to be a good deal, and they have a great page of instructions.
I may find a piece of scrap cast iron to practice on first...
