Yea I know, milage on 1st. tow?
03 honeycomb to 04 sport grille insert swap
Tire Pressure
Ok Guys, is this normal MPG?
I'm towing a 24ft inclosed car
trailer--total wt. loaded is about
8700#
4756 mi. round trip from So Ca. to
Ky. and back. MPG was a worst of 9. 9 and a best of 11. 4 Trk. has A/T
with 3. 73 gears SRW 2500 LWB
Total miles on Trk. now 7140. Is this NORMAL???
Everything else about it was fine.
Thanks, Sam
bballsam, I drove 1700 miles this month, noticed you did have a 2500, I averaged 11 mpg pulling a GCW of 20K lowest was 7. 8 with a good stiff headwind and 12. 5 on the flatland (what there was of it!) Your's sounds normal to me
2000 RPM in OD, speedo was at 70-72
When I pulled the grades, I locked out
the OD and went up the hills 55-60 at
2200 to 2500 RPM
Also, you were towing a box. That has more effect on milage then weight.
A friend and I went from Tulsa to Moab and back. He was pulling a tag car trailer with a Modified Dodge Durango on it. Aprroximately 8K lbs. total. He has an 04 HO 2500 Automatic 4x4.
I was pulling his 4K lb. travel trailer behind my '03 3500 HO 6-speed SRW 2wd.
At the speeds we were driving (70~75), his was 1 to 2 MPG better then me. The few times I dropped back to 60~65 my milage inproved dramatically. The drag was so bad, that going down a 6% grade, I could let off the accelerator pedal and the trailer would slow the truck down. Did not need to use the brakes. Going west down I-40 into Albuquerque I actually had to speed up to maintain highway speed.
Your milage would have been better if you had been pulling a flat bed instead of the inclosed trailer.
ditto on the normal. Speed kills (mileage that is!);)
Should get better over time, but I don't believe it'll change more than 2 or 3 mpg.
Dave
