year 1999 mods whats best bang for the $$$
Bosch 370 Diamond B inj
Boost with #8 plate
whats best mod for hp, cheap
can i move fuel plate on a 99 a/t trans
now its stock, 4. 11 gear 3/4 ton short bed
4x4 , any old used injectors with hp
increase that were replaced,
any thing to do to pump . ,
thanks in advance, bill
There is no fuel plate to move in the 24v.
Its all done electronically.
What do you consider cheap?
The EZ is popular or injectors. Both are roughly $500 (except 275 injectors which are usually $300) And the "stage" of injectors will change the price higher or lower.....
Here's my 2 cents....
Bill, for cost and bang for the buck, I woud recommend three things:
1) Upgrade the A/T to handle the extra torque.
2) Stage I or 275 injectors
3) Power Edge EZ Box
I put both of these on, and you won't believe it's the same truck!
If you decide to go MORE than this, you will be looking at upgrading other things leading to BOMBing mania and BIG $$$$. (It's addictive)
I am not the expert around here, but I can say that having the injectors and EZ box make a killer combination that is within the limits of the drivetrain.
Shawn
By far the biggest bang for the buck is going to be a fueling box like the Edge Power Edge or a TST Powermax or a similar box. They can give a ton of power for the money, but high EGT's are the usual consequence along with a need for a new clutch that will hold all the power.
The truck in question is a stock auto truck. Which is why I didn't mention any of the "major" fueling boxes. He wanted cheap... ... you can do an EZ or injectors on a stock auto.
Gauges are on the list as well. But if it came down to it I would have no problems running an EZ without gauges. But he didn't ask about gauges :D He asked for power... .....
its my brothers 99
my brother is asking me these things
plus if i ever change to a 99 motor for hp
ill know. his trk is the 99 a/t 4. 11 4x4
mines the 93 1st gen that got best of show
work truck 1st gen in vegas may 01 MM
me again
its for my brother 99 4x4 a/t 4. 11
he only wants to increase hp some
for towing no gauges,
whats the best for the least$$ for him
he has the stock a/t trans does not want
to change anything there
bill
