Year end statistics (how much did you use your truck last year)
F550 goes in tuesday!
curious about turbo terms
For those who track it, what are your year end numbers like?
I'll start:
Fill ups: 49
Total Fuel Used: 1,205. 989 gallons
Total miles drove in 2006: 22,373. 6 miles (second lowest since buying the truck)
Miles towing the camper: 1,523. 5
Total fuel economy (all driving): 18. 55 mpg
Max. single tank: 20. 86 mpg
Min. single tank: 11. 51 mpg
Most expensive per gallon fillup: $3. 18
Least expensive per gallon fillup: $2. 28
Average per gallon cost: $2. 84
Total cost of fuel: $3,420. 65
Total miles on truck 164,093
Replaced:
Rrear calipers/pads
Rear axil seals
Driver's side front wheel bearing.
I'll start:
Fill ups: 49
Replaced:
Rrear calipers/pads
Rear axil seals
Hmmm, looks like I need to get my book out...
steved
My numbers don't look near as good, but they are much better than what I saw driving a '95 1500 with the 360 (and pulling the same trailer)!
Fill-ups = 55
Total Gallons = 1349. 777
Total Miles Driven = 20,290
Miles w/camper or other trailer (6000# to 14000#) = 3,971
Average MPG = 15. 03
Max MPG, Single Tank = 22. 84
Min MPG, Single Tank = 10. 73
Most Expensive Fuel = $3. 379
Least Expensive Fuel = $2. 419
Average Cost Per Gallon = $2. 87
Total Fuel Cost = $3,877. 96
Engine Hours Accumulated in 2006 = 609
Average Speed in 2006 = 33. 32
Repairs: None
I have two diesels and drove them each about 1,700 miles this past year. At that rate , they will last an eternity. No need for parts :D
I put about 25,000 on my truck this past year. 1 trip to Moab and the rest of the miles from going to work, sled pulls, camping trips, etc.
I put just under 50k... slowed down a bit since I have a car to drive to work now...
Going to do this little bit of calculating once I get this final report done... then I can goof off... 50k worth of stuff takes some time!
steved
donnier said:
How did you arrive at the engine hours and average speed??
I think this function is only available on the 3rd Gens. There is a thread on the board someplace, but I think it is accessed using the triple key turn in the same way you get trouble codes.
As best I recall (the owners manual has the procedure) the engine hours on an '05 are pulled by holding the odometer button in, then turning on the ignition switch but not starting the engine. Once you have the hours, divide your total miles by the total hours to get your average speed to date.
We sure track some strange things; is that boredom, or do we really need to know?
Added about 30K to the clock last year.
It would be too painful to see how much I spent in fuel. :{ Lets just say a bunch.
In service 11/04
Miles as of 1/07 63,000.
Repairs: one axle CV joint.
Coupla oil changes, a fuel filter or two and a bath about every week. Original tires and brakes.
Just gettin' warmed up.
Steve
11,252 miles
749. 84 gals fuel used- $2,204. 41 total cost of fuel - $2. 939 price average per gal
11252/749. 84=15. 005 average miles per gallon
Oil changes at 2500, 5K, 7500, 10k - Valvoline Premium Blue
Lube front joint twice monthly - Valvoline HD silicone (red stuff)
Fuel Filter changes 5K and 10K - 7 micron
Air filter cleaned (Amsoil drop-in) 2500, 5K, 7500, 10K
Weekly Bath and Interior cleaning
ABS Module recall and replacement, fuel tank vent recall, two reflashes-P0191 code,
1 reflash white smoke.
CD
Fill ups: 34
Total Fuel Used: 1,089. 476 gallons
Total miles drove in 2006: 16,561 miles
Total fuel economy (all driving): 15. 632 mpg
Max. single tank: 18. 581mpg
Min. single tank: 13. 484mpg
Most expensive per gallon fillup: $2. 999
Least expensive per gallon fillup: $2. 399
Average per gallon cost: $2. 660
Total cost of fuel: $2,897. 54
Total miles on truck 46,892
01 Cummins= 28,000 miles this year
02 Cummins= 28,000
06 Cummins= 31,000 since May
I don't have all my numbers.
I put all of the miles on the 01 myself and 7/8 of the ones on the 06'. and I put very few on the 02' myself.
$25,000 in fuel.
Fill ups: 61
Total Fuel Used: 1600. 286 gallons
Total miles drove in 2006: 22,228 miles
Total fuel economy (all driving): 14. 32 mpg
Max. single tank: 21. 65 mpg
Min. single tank: 7. 91 mpg towing over 14,000lbs
Most expensive per gallon fillup: $3. 299
Least expensive per gallon fillup: $2. 419
Average per gallon cost: $2. 73
Total cost of fuel: $4399. 02
Fuel cost avoidance compared to my former Tundra: $1252. 27 Oo.
Total miles on truck 59882
Daily driver
Prior to 4 31 06 No Records kept
Fillups: 32
Total Gal: 2160. 71
Most paid: 3. 39
Least Paid: 2. 59
Average: 21. 51
Fill ups: 37
Total Fuel Used: 1090 gallons
Total miles driven in 2006: 20219
Miles towing the trailer: 300
Total fuel economy (all driving): 18. 55mpg
Max. single tank: 19. 30 mpg
Min. single tank: 12. 55 mpg
Most expensive per gallon fillup: $3. 26
Least expensive per gallon fillup: $2. 56
Average per gallon cost: $2. 90
Total cost of fuel: $3132. 18
Total miles on truck 86357
I know that for the '06, turn the key to the "RUN" position (not start), and with the odometer (not trip counter) showing, press and hold the trip reset button on the dash. After about 3-5 seconds the hourmeter will display the engine hours.
I don't know if this is done differently on earlier trucks...
average mpg=17
total miles 120,500
7000 since truck was purchased in april
repairs
rear brakes
Fill Ups: 19
Total Fuel Used: 480. 66 US Gal
Total Miles Driven: 9756
Total MPG: 20. 30
Max Single Tank MPG: 24. 31
Min Single Tank MPG: 20. 46
Most Expensive Gallon: 3. 16
Least Expensive Gallon: 2. 27
Average Per Gallon: 2. 56
Total Fuel Cost: 1181. 56
Total Miles: 210,000
Math is weird on MPG, but that's the way it adds up.
I drove more miles last year, the car is cheaper with the cost of diesel. Mostly running the Dodge when I'm hauling something in the back or kids (no airbags, kids get to ride in the front seat).
Replaced: Starter, battery cable, heater core, 6 gallons Delo.
Needs replaced: :eek:
