Yet another ETH fueling box question
Heavy Duty Tires
new guages
Has anyone (other than Mike V. )tried running a TST Power Max adjustable or the new JVD box on a ETH ? I spoke with Mike V. thru several e-mails, and while he thought that the TST box was adding more fuel than the PE box, he said the EGT's were way too high. My truck's going in at the end of the month for the Mcleod install, a 3 piece BD manifold, HX-40 turbo and 4" exhaust. I'm also putting in the Bully Dog stage III injectors. For now, I'll be using the Edge EZ box that already have installed and really like. Any comments, as always, are greatly appreciated. Thanks in advance.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
[This message has been edited by Bigsaint (edited 01-18-2001). ]
Let me know if you get any kind of major hp increase I am looking for enough fuel to run twin turbo's
2001. 5 ETH/DEE DD3's EZ HX40 machined out for more flow, Custom 4" exhaust turbo back staight pipe with 5" chrome tip in front of rear tires,spa's, mcleod clutch, more to come
wiz1... I'll let you know. I'm leaning towards either the JVD box or the TST Powermax but have to sell the "hot" PE first.
Do you know who is doing the fuel pump mods. that are needed for more fuel on the ETH's ?
Scott W.
Sheesh! #ad
Most people just stick their toe into the Bombing Pool and check out the water. Not you, BigSaint! You're diving head-long into the deep end!!!! Not to worry, the water's fine. #ad
98 QC 3500 4X2 ISB 5-speed; 10-level Competition PowerMax; DD Stage II's; 4" exhaust turbo to tip; Luk ProGold; K&N; Amsoiled; Pillar Mounted Boost & Pyro; etc. , etc. ,
Big,
The only place doing the injector pump mods is Diesel Dynamics. No one else wants to tackle the VP44 pump. You have to admit,there is alot of liability in tearing apart someone else's injector pump.
Why don't you just trade the "hot" PE box back to Edge for a "standard" box? Would seem less headache to me.
Before you go and install all the power adders at once,take a step back and try each power adder one by one,that way you know how each performance adder is suppose to work on its own. I would hate to see you throw the whole combo in together and find something doesn't work well with something else and not knowing why.
With the step III's and an EZ,you are going to find your truck is going to be too fast for any road or highway with traffic on it. So see what you think about the performance before you throw a box on top of all that.
-Mike
'00 2500QC,4x4,LWB,Dark Garnet,6spd,3. 54lsd,SLT,DD stage II,Psychotty air,10-level PM3,Jacobs ebrake,Isspro pyro & boost gauges,2wd-low,Airoquip fuel lines,Smittybilt nerfs,BFG 285/75 AT's,Midland cb,Clarion 6-disc changer
Mike... I think thats probably good advice. In all honesty, I had planned on just driving with the truck as described with the above mods. for a while. Right now I'm just posting questions to try to plan for future bombing.
Thanks again for trying to keep me sane !!!
Scott W.
Ross... when I look in the mirror and say three times "I'm not a bombaholic" I detect the faint smell of diesel, do you think I'm too far gone for help ? LOL
Thanks for the update on the water in the "bombing" pool but I already stuck my toe in several months ago with the EZ, after that it was over but the shouting (being done by the wife) #ad
Scott W.
Scott,
If you've already got a PE box, then it's a waste of money and time to trade it for any other fueling box on your ETH, especially with the addition of injectors. If you don't have a fueling box, save your money and use it toward the reworked DD pump, when it becomes avialable. The ETH VP44 only puts out so much fuel, and NONE of the fueling boxes are helping it any more than the others. Fueling boxes only make sense on an ETH with stock injectors.
I will have dyno figures for the ETH with PE and DD3's some time next week. I'm betting that the power increases will be under 25 horse no matter how much the box tells the pump to fuel. Right now, injectors, HX40, and an EZ or VA are the best way to go with the ETH.
I just talked to HeberRam today after he dynoed his ETH at Edge. He is getting 20 more horse with DD2's and EZ than I got with 275's, EZ, and PE.
Bart
Thanks again Bart, what I figured but thought I'd throw it out for some extra feedback. Oh well, $700 for another box is almost 1/2 there for pump modifications. Looks like I'll try the above mods. and hopefully that will keep me happy for now.
Forgot to add... The only reason I re-posted this topic was to see if one box was making MORE hp than another with the ETH. I still find it hard to beleive that the EZ alone max's out that VP44 when some of the other box's claim so much more of a hp increase on the ETH. I now realize that piggybacking a EZ with any other box on the ETH will be a low gain. Would any one single box provide a higher hp gain than just the EZ ?
Scott W.
[This message has been edited by Bigsaint (edited 01-19-2001). ]
Hey scott are you going to send your pump off to the boys to have it tweeked once you get the setup running let me know how you like the HX40 EZ and DD3's omne thing you will need to do is upgrade the fuel lines I have seen as low as 4lbs of fuel pressure I will be putting in the psycotty next to see what it will do for my egts
All you ETH boy,s should think about putting a ETC pump on your trucks. So far on my truck it didn,t matter what injectors or plug-in boxes that I used,a hot programed clip-on box adds 100hp. If you can only pick up 20,thats a 80hp difference. You can also have the pump modified for more power.
John/SP
2000 3500 2WD QUADCAB 5SP 3. 54 525HP!!!
[This message has been edited by sport bike (edited 01-19-2001). ]
Sport Bike, I think that's a good suggestion as it would probably just be a direct bolt-on. Wish I'd have thought of it. Marco claims the ECMs are identical between both engines. It's downright fustrating, after you've paid extra for the ETH, when an ETC with the same mods makes more power.
Scott, some boxes may indeed make more power on the ETH, but only with stock injectors. Actually the PE will make more power than the EZ on an otherwise stock engine. After you change the injectors everything changes concerning the boxes.
sport bike... I've thought of it but was unsure of compatability issues. What's an ETC pump go for? I thought that I heard our fuel pumps cost around $1500 or is that the price to upgrade an existing pump? No doubt on the frustration level. For a "bomb'er" you would be better going with a 5 speed ETC. I never would have figured that and I have to laugh when I read the VP44 is designed to increase performance. LOL
Bart... I am real new to diesel engines ( this is my first and I've only had her for 4 months now). Why is it that the injectors change the picture when you swap from stock to custom ? I'm not questioning you, just trying to understand.
wiz1... I'm not ready to modify the pump yet, but may be look'in that way sometime in the future. I'll post an update, when the planned upgrades are all installed and "road tested".
Thanks again to all that replied !!!
This site is unbeatable for top info #ad
Scott W.
Hey that etc pump thing is a good Idea I need to check into that because if that works then the twin turbos are coming soon wow an eth with twins and enough fuel to spin them thats pretty scarry,does anyone have a part number on a etc pump thanks wiz
