Engine/Transmission (1998.5 - 2002) Yet another Exhaust Brake question
Engine/Transmission (1998.5 - 2002) cuttin out/power surges
Engine/Transmission (1994 - 1998) 330's in a 160 pump?
OK yall, I've searched the threads for the answer to my question with no luck... It states that once the system is installed to start the truck and check the back pressure... What or where is the doo hicky to adjust the amount of back pressure? The brake is an inline BD brake... Im at a stand still right know and waiting for a possible answer so I can get this thing working tonight... ... ..... Hell if someone has a BD brake on their 2001-2002 6 speed and is willing to talk to me on the phone PM me and Ill call you !!!!!!... ... ... . Thanks in advance... Jeremy
the back pressure on a BD vacuum operated brake is controlled by loosening or tightening the linkage between the canister and the arm that is welded to the butterfly valve.
If your brake is air pressure rather than vacuum activated, it may require a different adjustment method. If you don't have a BD manual for your brake, you can download one at bd-power.com and click on manuals. Select the one that looks like yours.
Dan
