Ok, I need some lift pump pressure advice for my ’04 HO. Before anyone says anything…yes, I did use the “search” function before I posted up this question.
I used a test gauge from GDP and used the test port on the billet fuel filter cap from Geno’s to get my readings. As you can see in my sig I’ve got a TST, 2 micron filter and big line kit from GDP and that’s about it for mods that would have any effect on the fuel pressure. The truck has 84K miles on it, I’ve owned it for about 10K of that and the TST has only been on there for about 3-5K miles.
I ran the following pressures (with TST on 4/4):
*at idle: 6-7psi
*Cruising: 5. 5psi
*WOT: 4-5psi
Are these acceptable? From what I’ve been able to find online here I guess the port on the Geno’s cap is PRE fuel filter(s) so I guess conceivably the pressure at the CP3 inlet would be less than what it’s reading at the fuel filter cap…. does that sound right?
I use the truck as a DD and tow 6-12 times a year a load of about 10-12K pounds and my overall goal with this rig is to get to about 500hp/800tq. I know that eventually I’ll have to get a lift pump to get to those goals but I want to know if I need one sooner than originally planned.
Thanks in advance for your help!!!
*at idle: 6-7psi
*Cruising: 5. 5psi
*WOT: 4-5psi
