I just copied and pasted this from cummins QSOL, sorry the small med large are the pics that wont copy
Fuel Lift Pump
(005-045)
Table of Contents
Summary
Initial Check
Remove
Disassemble
Test
Install
Summary
Measure pressure drop. Max: 34 kPa [5 psi].
Turn keyswitch ON and check fuel lift pump operation.
If pump not working, check voltage and resistance at lift pump. See detail.
If not to specification, check for good power supply.
Disconnect the fuel line between the lift pump and the fuel filter.
Plug the outlet of the lift pump.
Check for leaks at the lift pump or fuel line fittings.
Inspect the lift pump and the fittings.
Disconnect battery. Negative cable first.
Clean fittings and components.
Remove fuel lift pump inlet and outlet fuel lines (Procedure 006-024).
Disconnect the fuel lift pump harness connector.
Remove the mounting nuts and pull the lift pump down and out of bracket.
Disconnect electric fuel lift pump power leads.
Remove three cover screws and cover.
If suspect plugging, clean pump.
Measure output pressure. Use pressure gauge.
Turn keyswitch on and start engine. Max during cranking: 41 kPa [69 psi]. Min during idle: 69 kPa [10 psi].
Measure output pressure on fuel filter head. Use pressure gauge.
If not to specification, check for plugged inlet screen on pump. Clean if plugged.
Measure fuel inlet restriction. Refer to Procedure 006-020.
Install lift pump cover.
Install pump in mounting bracket. Torque: 12 N•m [106 in-lb].
Make sure the inlet and outlet are orientated properly. See detail.
Connect the harness connector to fuel lift pump.
Initial Check
TOC
WARNING
Fuel is flammable. Keep all cigarettes, flames, pilot lights, arcing equipment, and switches out of the work area and areas sharing ventilation to reduce the possibility of severe personal injury or death when working on the fuel system.
WARNING
Do not vent the fuel system on a hot engine; this can cause fuel to spill onto a hot exhaust manifold, which can cause a fire.
CAUTION
Do not operate the fuel system with a suction restriction of more than 3 psi.
A malfunctioning electric fuel lift pump can cause low power or rough running from the engine. The fuel lift pump can be cleaned and repaired to a limited extent.
SMALL | MEDIUM | LARGE
The pressure drop will increase as the filter removes contamination from the fuel. Therefore, a worn fuel lift pump will have reduced capacity to force fuel through a dirty filter. This can cause low engine power.
Pressure Drop Across the Fuel Filter
kpa psi
34 MAX 5
NOTE: Frequent filter replacement to get full power from the engine can indicate a worn fuel lift pump.
Check for fuel lift pump operation by turning the vehicle keyswitch to the ON position and listening or feeling for operation.
NOTE: The fuel lift pump will run for 2 to 3 seconds when the keyswitch is first turned on and then it will shut off. It will run while the engine is running. It will also run for 25 seconds after a failed start attempt with the key on. This can be used to aid in priming the low-pressure lines after a filter replacement.
If the fuel lift pump is not working, check for voltage and resistance at the lift pump.
If the voltage does not meet the specifications, check for a good power supply.
System Voltage Resistance
12 VDC MIN 9 VDC 0. 1 ohm
12 VDC MAX 2. 0 ohms
24 VDC MIN 21 VDC 0. 1 ohm
24 VDC MAX 4. 0 ohms
NOTE: All fuel must be drained from all fuel lines, if observed.
Apply the vacuum test to the fuel system and check the vacuum gauge. The vacuum can not exceed 381 to 508 mm-Hg [15 to 20 in-Hg].
If the system holds a vacuum (if the reading on the gauge does not reduce, the vacuum should not drop more than 2. 54 mm-Hg [0. 1 in-Hg] in a minute), then there is no leak in the fuel system.
NOTE: The vacuum test is completed if the fuel system holds vacuum for at least 5 minutes.
If the system does not hold vacuum (the reading on the gauge does not hold and reduce to 0 mm-Hg [0 in-Hg], then there is a leak in the fuel system.
If the system does not hold a vacuum, check for leaks at the lift pump or fuel line fittings.
Inspect the lift pump and the fittings. Replace and install parts that are malfunctioning or damaged.
Remove
TOC
WARNING
Batteries can emit explosive gases. To reduce the possibility of personal injury, always ventilate the compartment before servicing the batteries. To reduce the possibility of arcing, remove the negative (-) battery cable first and attach the negative (-) battery cable last.
Disconnect the battery, negative (-) cable first.
NOTE: Thoroughly clean fittings and components before removal. Make sure that the debris, water, steam, or cleaning solution does not reach inside the fuel system.
Remove the fuel lift pump inlet and outlet fuel lines. Refer to Procedure 006-024.
Remove the three fuel lift pump mounting nuts, and pull the lift pump down and out of its mounting bracket.
Disassemble
TOC
WARNING
Fuel is flammable. Keep all cigarettes, flames, pilot lights, arcing equipment, and switches out of the work area and areas sharing ventilation to avoid severe personal injury or death when working on the fuel system.
Disconnect the electric fuel lift pump power leads.
Remove the three screws on the cover of the fuel lift pump.
Remove the cover.
The fuel lift pump is an electrically driven vane-type pump. It contains a relief valve in the head of the pump to recirculate fuel; this prevents over-pressurization of the injection pump and protects it from damage.
The fuel lift pump also has a screen on the inlet to catch debris and protect the pump. It can be cleaned if suspected of being plugged. A plugged inlet screen can cause low power and/or white smoke.
Test
TOC
The output of the fuel lift pump can be checked through the following test:
* Measure the output pressure using a pressure gauge at the fuel filter head tap.
Pressure Gauge and Hose, Part Number 3375932
Turn the keyswitch on, and start the engine. Measure the output pressure of the fuel lift pump by using pressure gauge, Part Number 3375932, at the tap on the inlet side of the fuel filter head.
The minimum lift pump pressure allowed during engine cranking is 41 kPa [6 psi]. Once the engine has started and is idling, the minimum lift pump pressure is 69 kPa [10 psi].
Lift Pump Pressure
kpa psi
Cranking 41 MAX 6
Running 69 MIN 10
NOTE: At initial key on, the lift pump will run for 2 to 3 seconds and then stop. During cranking, the fuel lift pump will run at half-duty cycle (approximately 6 psi at the output). Once the engine is running, the lift pump will run continuously. If the engine will not start, the lift pump can be checked by cranking the engine for a split second and releasing the keyswitch to the ON position. The lift pump will then run for 25 seconds.
If the minimum pressure is not within specifications, check for a plugged inlet screen on the fuel lift pump, to disassemble the lift pump.
Clean the inlet screen if it is plugged.
Measure the fuel inlet restriction before the fuel lift pump.
Measurable restriction is another possible cause for low lift pump pressure. Refer to Procedure 006-020.
Install
TOC
Install the fuel lift pump cover.
Install the fuel lift pump into the mounting bracket.
Torque Value: 12 n. m [106 in-lb ]
NOTE: Make sure the inlet and outlet are orientated properly. The words IN and OUT are stamped on the top of the fuel lift pump. The line from the tank must go to the IN side, and the line to the filter head must go to the OUT side.
Connect the harness connector to the fuel lift pump.
NOTE: If the original lift pump had a non-integral connector, then extension harness, Part Number 4025182, will be required.
Last Modified: 10-Feb-2006
Copyright ©2006
Cummins Inc.
All rights reserved
